Discuss air to water heat pump in the Central Heating Forum area at PlumbersForums.net
Hey everyone, a client of mine has a ''Dream'' air to water heat pump and the control panel is acting up. The on/off button won't work, everything else works fine. So it needs to be replaced. Where on earth can I buy a replacement and if I can't find the exact one is there such a thing as a generic unit that works with all pumps?
Many Thanks
The only source of spares I am aware of for Dream Heat Pumps is World of Bargains Ltd., in Leicester. They are the sole UK importer of Dream equipment. In my experience service for parts from them is patchy.
The controller will be a brought in item by Dream.
If you want to reconfigure the pump, it will probably run on a Toshiba Estia control unit - it is the same family of Toshiba compressor units that Dream use.
Reply to air to water heat pump in the Central Heating Forum area at PlumbersForums.net
