Discuss "All in one" tile drilling solution still remains the best selling solution from 365 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
365drills
As we begin a new year
I thought it worth posting up some information introducing
new forum readers to our No1 best seller the "bathroom fitters kit".
This simple solution has a combination of the service pipe sizes for a bathroom (example: Radiators, Shower Head, Waste, 22mm Bath pipe) and also a selection of 6mm and 8mm cores to tackle the red rawl plugs and brown rawl plugs for fitting fixures and fittings. (example: loo roll holder, mirror, shower screen, robe hook, soap dish, cabinets).
The service pipe cores can also be used to open up (widen) holes to suit ANY size that you may need in a tile.
For those of you new to the Tilers Forums here is the best selling tile drilling solution for very hard tiles:
http://www.*********.com/jpgs/bfk4.jpg
At £49.99 (£41.66 plus VAT) the drills work out
at an incredible £5.95 each plus VAT !
http://www.*********.com/jpgs/valueformoney2.gif
Including 20% VAT
You simply cant buy them in the shops that cheap. And the reason is that 365-Drills are the UK manufacturer of them.
Made in a UK factory.
http://www.*********.com/jpgs/guideplate.jpg
Each pack has a FREE anti-slip guide plate so that you can drill without skating on the tiles.
You do not have to spend extra cash on complicated and expensive clamps which can fall off the wall.
http://www.*********.com/jpgs/sponge4a.jpg
We even offer a simple explaination of how to use water to cool by using a wet sponge
Why waste £30 or £40 of your money on water cooling systems which add cost and is an additional ***bersome step?
Yes we sell the sponges (if you want them) for £1.75 but we make it very clear you can utilise your own.
Re: "All in one" tile drilling solution still remains the best selling solution from
http://www.*********.com/drilling_blinds/19.jpg
Lightweight easy to use equipment gets you fast access into awkward areas.
http://www.*********.com/jpgs/tile_drill18.jpg
Drilling to milimeter perfection on those expensive porcelain tiles.
Wont break them too!
http://www.*********.com/jpgs/tile_drill6.jpg
Accesories and fittings are fitted with perfection on any tile
http://www.*********.com/jpgs/a7.JPG
Holes for service pipes are perfect every time. At 16mm 30mm and 40mm
http://www.*********.com/other/17.jpg
So for example radiator pipes look neat.
http://www.*********.com/cer1/Dsc07724.jpg
Shower heads and shower valves come through easily.
http://www.*********.com/cer1/Dsc07702.jpg
Here you can see the typical waste pipe (32mm) and the hot / cold feeds at 15mm for a pedestal - sink.
Again elegant and simple.
CUSTOM
At ********* because we have our own factory we can produce ANY size you need. It doesnt have to be a drill size on the standard list.
We can also custom build any set that you choose. Just tell us what sizes you need and we can pick from stock.
If you dont want a twin pack of 35mm and just need a single. Then just ask.
http://www.*********.com/google/35mm.jpg
http://www.*********.com/build/34.jpg
Perhaps you are just drilling ONE single hole for a granite worktop to fit a basin. Why do you need a twin pack?
So call and tell us what you need for the job.
http://www.*********.com/build/1.jpg
Example customer only needed a hole for waste and a hole for tap (35mm tap and 42mm waste)
So we supplied a combo pack to the plumber.
Want to know the benefits of the system by video?
[video=youtube;W2CXLSjpVhU]http://www.youtube.com/watch?v=W2CXLSjpVhU[/video]
Ready to see the endurance test of our ultra hard diamond core drills on a number of materials.
[video=youtube;NjuUmSksArQ]http://www.youtube.com/watch?v=NjuUmSksArQ[/video]
Please contact us at any time to discus what YOU or your installer need. And we are ready to help you.
Still got and still using the kit I bought last year and it's done hundreds of holes in the hardest materials. Highly recommended by me!
Reply to "All in one" tile drilling solution still remains the best selling solution from 365 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Here they are! Totally refreshed for this year. We have given a makeover to all of the BOXSET range. All options are now presented in smart...
2K
365drills
  • Locked
A positive early response to the "Installer Magazine" splash on PORSADRILL. Tile Drilling Specialists 365-Drills have modified their publicity to...
2K
365drills
  • Locked
Brand new for April 2016. Launch of boxsets for drilling holes into very hard porcelain tiles. Two sets have been revamped. The third is...
1K
365drills
  • Locked
Welcome to ********* and one of our projects which deals with drilling holes into ceramic sinks (Kitchens) or ceramic basins (Bathrooms). If you...
4K
365drills
  • Locked
After four hours of driving from London we reached Preston. And Installed the PORSADRILL diamond core tile drilling system for very hard...
2K
365drills
