Discuss Alpha CB25 pressure rise problem in the Central Heating Forum area at PlumbersForums.net
Hello everyone,
I have a problem with our Alpha CB25 boiler.
Problem is little bit complicated to me.
We have had a problem with hot water this summer. I changed two parts like heat exchanger and I refurberd divert valve.
We always have problem with low pressure I have to fill it up the system every fortnite. We do not have leak our heating system I already checked all radiators.
Today I woke up and the main pressure raised to 3 bar. We used only central heating at night. I thought the problem could be water refill circuit but I closed the main water tap and the pressure went up over 1.5 bar but its stopped. When I open the main water tap pressure rising up immediately.
Can you give me any advice where is the problem? Which parts can be changed?
Ohh.. Yes I forgot, I've changed the PCB as well because the ventilator control has gone my old board.
Thanks fo any advice
Reply to Alpha CB25 pressure rise problem in the Central Heating Forum area at PlumbersForums.net
