Discuss Alpha cd50 intermittent fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gary
Anyone have good experience with the Alpa cd50. This boiler has a 50lt hot water store, designed to give 16 lt per min flow and as it empty's the burner kicks in to take over.
My client is saying that it delivers hot and then sometimes goes cold for a few seconds and then hot again (a nightmare when in the shower i expect).
He also says sometimes it starts of cold, this makes no sense at all.
just thought i'd put it out there to see if anyone had any ideas. The Alpha guys are far from helpful.
Cheers.
If it cuts out in a hw run off, It'll could be one of the NTC sensors failing, replace both of them,
If it doesnt fire up at all, to heat the store or whilist hw run off, could be the spark generator,
Is the divertor valve leaking??
Reply to Alpha cd50 intermittent fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Am trying to understand my mother's Apollo boiler. It has an intermittent fault. In the last couple of years, it has had a new...
Hello All- (Usual caveats apply: I am the rather unusual part-time variety of a GSRE, training self-funded and slowly trying to make my way and...
I have an Albion indirect mainsflow thermal store installed in July 2011 with a 120 litre capacity. I live in a block of communal council flats...
1K
  • Locked
Hope you can help with this one. Its an intermittent problem, which makes spot diagnosis by an engineer very challenging. Two heating engineers...
4K
  • Locked
So I've an ideal logic 35+ and it seems to only give hot water sometimes from my mixer taps in shower and kitchen. When using the bath tap it's...
3K
Dotty
