J
jamesbak
Hi guys,
I've been left in a stick situation by my plumber. The job started as new central heating for the house but upon starting works it was discovered that all piping was lead and needed replacing. This has now been done including new pipework to water main and central heating off a combi.
I am also having a new kitchen fitted so first fix has been done for that.
The problem is that I thought that the old copper piping in the bathroom would be plumbed back in so that i can just fit the new bathroom to existing pipework and maybe run a pipe from the bath to a shower (not electric). Unfortunately it turns out that the plumber didn't quote for that (through my builder so never actually spoke to him directly) and Unfortunately it turns out that the plumber didn't quote for that (through my builder so never actually spoke to him directly) and I was never told.
This means that to get a bathroom in again before Christmas I'll have to do it myself or try to pay someone "emergency" rates to get it installed.
The plumber has left a cold and hot feed terminated under the floor under the WC in the bathroom for me to work from but I'm not sure how to proceed.
Looking at articles on the internet it seems I can just run off pipes using t-connectors, connect to existing wastes and Robert's your father's brother or more precisely no-one says what you can't do only "connect up the hot water feed".
Am I missing something or would it be this simple? Can you run a WC, basin, bath and shower off a single hot water feed and single cold water feed?
Is there some fancy jiggery-pokery I need to do to ensure correct flow?
I read that I should install isolator valves for each tap, etc. to be able to easily maintain, anything else I should consider?
I'm planning to just use push-fit style connectors and plastic pipe for the job to avoid any welding or soldering. I assume it will be possible to connect to the metal taps etc. with plastic pipes.
I know these are fairly basic questions but I thought it best to ask the experts as I only have tonight to figure out what to do before making a start and I don't want to be swimming into my new kitchen.
Cheers in advance guys,
James
James
