Discuss Ancient shanks siphon repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gassafe
Anyone tried repairing one of these old relics... Is it just a regular membrane inside?
I cant replace for a regular as it has a really weird connection on to the pan, plus 2' plus siphoning pan!
Pics
image.jpgFunny round nut securing...
For some reason page go's black if I click on your photo's ????????????
The round bit is a shroud. It will either pull down if you put a scraper or something in. Might be stuck up with putty or it will have a thread on it you should be able to turn with your hand.
Use a bit dpc or heavy visqueen for a new washer and punch a hole through it with a bit 10mm pipe rather than trying to cut it
These photos have going black with me as well but can still see page behind.
All done, the round nut was a shroud... There wasn't a membrane as such, like a big metal type disc in there that had corroded & fell apart... Luckily my membrane material worked okay, fingers crossed it holds lol!
Reply to Ancient shanks siphon repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet...
2K
Hello, I have had a Saniflo PRO XR for three years. Still under warranty and I put cleaner/descaler every three months. It is used once or twice...
3K
Morning all, as always can never find an exact existing thread / discussion where I don't feel like I'm making one too many assumptions. Can I...
1K
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
