Discuss annual boiler service in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
G
Glow20
I recently had a service on my worcester bosch boiler by Warmserve supposedly reputable which is under guarantee and before the service I had no problems but straight after the service I had a leak from the boiler which when the service engineer came back told me I needed a new condensate trap! This has now been fitted and cost £80 plus vat without cost of service! Why did this happen straight after a service? What is the point of having a service which is supposed to stop problems not create them and is there any redress?
Sometimes when you service boilers, things break.
Sometimes when you service boilers, parts have to be replaced.
Sometimes when you remove a condensate trap to clean it, it breaks or leaks when you reinstall it.
I'm convinced it's a part that has been 'designed to be replaced' at least once in a boilers lifetime.
Didn’t grease the oring before refitting common issue also you can buy a new oring separately
Eg pn 87161138330
Reply to annual boiler service in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
R
Hello Just a quick question. I had a new Vaillant ecotec plus boiler installed in Nov 2021, with a 10 yr extended warranty. I've been trying to...
Vaillant Ecotec Plus 832 boiler is 13 years old, 4 of which since we've been living there, started to play up in last couple of months. An...
Just had a new worcester bosch. 1000 combi boiler to replace 18yr old vokera. No problems with new boiler. Enquiring about yearly maintenance /...
I have a Vaillant Ecotec Plus combi boiler that was installed just over 6 years ago. It has been serviced annually, the most recent service being...
3K
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the...
