Discuss Any idea as to what’s happening in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I think that your cold water feed could be blocked,your inlet will have a filter in it .
i am not willing to tell you what to do as it will invole electrics water shut off poss remove unit. etc.
please get plumber/sparky for your safety,
I’m a multi skilled maintenance engineer, so isolating the shower isn’t an issue and I’ll just turn the water mains off. As to plumbing I don’t have a clue hence why I’ve asked for advice on here first
My first thought was blocked filter. I believe on the quartz (which is the shower you have) the 2 screws just after the brass elbow is the filter. Take this out and check to make sure its clean. I doubt you have the flushing piece which screws onto that position which you could use to test the water supply with but if you do then check that out as well.
If your supply is good and the inlet is clean then its time for a new engine. They aren't particularly expensive and are easy to fit.
Basics first.
Remove the shower head - if the shower now runs as normal, the head needs descaling/replacing.
If it still doesn’t run properly: remove the hose, if it now runs properly the hose needs replacing, it will have a hernia inside somewhere.
If this doesn’t resolve it; move onto th Ec filter as per fowlerboi.
Then it’s either remove unit and descale tank, or just replace unit.
Reply to Any idea as to what’s happening in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Toilet continuously flushing/cistern filling. This happens regardless of what else is going on within the house (videos were taken before and...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Hello, purchased a house in February this year and for a few weeks, noticed a loud banging noise which sounds like it is coming from under my...
Hello Yesterday my aqualisa shower sharted making a whirring sound and trickles of water came out of itwhen the boiler came on to heat up the...
I own a Aqualisa Q shower but the pinch grip holder has broken but how to do get the bottom part off (see attached) so I can feed the new...
2K
