Discuss Any ideas of how to remove the nut on a high level WC cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have been unsuccessfully trying to remove this nut to release the syphon from a high level cistern. The pipe is plastic so I cannot heat up the nut. I have tried freeze it spray which usually works but not on this occasion.
Any ideas? 2016-09-27 16.38.02.jpg2016-09-27 16.38.10.jpg2016-09-27 16.38.02.jpg2016-09-27 16.38.10.jpg
get a pair of grips on the threaded part and a decent adjustable spanner on the nut, should come off with no problem!
Just don't mangle the thread up.
As above, ^^ just use large adjustable or grips on the nut and hold the top of syphon with your other hand to prevent it turning. Only use grips on threads as last resort and don't let them slip on the threads and damage them badly.
12 inch Footprints are great grips
Morning, is that not an
old Bakelite cistern ?
I know this may cause alarm unnecessarily and I don't mean to because it's extremely unlikely any thing might happen but Bakelite sometimes had asbestos mixed in with it for strength.
It's unlikely you will scratch damage or crack it but please be careful with it !
my apologies if it's plastic
I think Last Plumber is right. I think them cisterns do have an element of asbestos in them. We used to have to get a licensed asbestos removal company in to remove them when I was working for a local council.
We was always told not to disturb them - just replace the cistern. I think in reality I would recommend, that if you have to put too much pressure on breaking the nut, quote for a new cistern. Dudley do a rubber well at most suppliers.
Hi Everyone
Many thanks for your replies. The WC has been there a long time, it is probably bakelite. I did manage to break the nut seal with two extendable spanners and "Crack it" spray. Fitted a Dudley 88 syphon easily in its place.
Paul
Reply to Any ideas of how to remove the nut on a high level WC cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
