Discuss Any tilers in the Arms tonight ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
My first attempt at a envelope into a liner drain what's the best way to bring it back the tiles back into bond . Cheers kop
Reply to Any tilers in the Arms tonight ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
