Discuss anyone used Geefix fittings to hang radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Paul and welcome,
Never seen them before but looking interesting to me. I cannot tell you really if they're good or not. My experience with spring toggles or hollow wall anchor are good. I cannot complain about those cavity fixings. I was just thinking if you really had so much space to fit the big plastic inside the cavity ? Sometimes you won't have that much space but It's worth trying the geefix if you ask me. I definitely will give it a go thanks for sharring.
I would say no from me plasterboard will only hold so much all your doing is spreading the load out to a bigger surface area and in theory this is great, but the base material needs to be able to take the load
Anything over 1m x 60cm is a no go for plasterboard unless your fixing directly to timbers behind
Thanks for the reply. I will let you know how I get on
Thanks for your thoughts. Will post how I get on. Ideally I would have liked timber instead of plasterboard but I think the Geefix will be my best option
Hi, I recently used these Gee fixings and would recommend them. They are holding very securely a towel radiator 1100mm X 600mm. Very neat and easy to use. However I would suggest only using them as a last resort as a stud is the best choice
Reply to anyone used Geefix fittings to hang radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
