Discuss Apollo Boiler keeps cutting out and making banging sound : ( Please Help I’m all cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mavmbuk
Hi all,
Am hoping someone can give me some advice on what i can do / diagnose my problem i am having with my Apollo 15/30B wall mounted Gas boiler.
I have recently moved into my 1st house and been here for about 2 months. As its starting to get allot colder i decided
to switch on the heating as its been off since i moved in. So turned the boiler from off to High and great it fired up and then after about 30 seconds
starts making a banging sound :confused:and after a minute it cuts out with just the pilot light staying on for about 35 seconds and then it will repeat. :mad:
I have also made a shot video clip so you can see/hear the problem.
[ame="http://www.youtube.com/watch?v=SHWgzs53q0E"]YouTube - Apollo[/ame]
Am grateful for your time and help. :cool:
Re: Apollo Boiler keeps cutting out and making banging sound : ( Please Help I’m all
top marks for graphics,
fast trackers will wet themselves for this one, just like being at school.
it looks dangerous to me, needs a good service, nothing you can do yourself here call out g.s.i.
Well would say your heat exchanger is blocked up or the central heating pump is stuck/siezed
Water is being heated in boiler ,not circulting and banging caused by overheating
If boiler been off for a while you may be able to free pump off,turn boiler thermostat to off ,turn heating on ,go to pump and tap back of pump with a hammer,not to hard to try to free off,if pump has a chrome screw in middle of pump,you can also try to undo and you will see a spindle place small screw driver in end of spindle and rotate clockwise to try to free off,if in centre of pump you see a plastic nut looosen off anti clockwise to try to free pump
If all that fails,afraid heating engineer required
ps impressed with you tube insert,why to go !!
Needs a good service. Strangely the noise to me doesn't sound so much like kettling as a gas valve snapping shut, its a very metallic sound. It may be the overheat stat shutting off the gas valve though.
As a tip get the service engineer to check the water supply to the boiler. Had a case years ago where the feed and expansion cistern was full but the cold feed to the boiler was blocked.
i have had this before where it kettles and been off over summer and gone in
the loft only the find ballcock stuck in the off position and the water has
evaporated and not helping the circulation..have a look
Got a guy out to have a look and it was the pump had seized and felt red hot. But he said he would see if it would free up, so he unscrewed the big middle screw and it came back to life : )
Got him to service my boiler so all in all it cost me £45 :D
Only prob is that the day after he had got it working it is now starting to sound not to healthy as it sounds like the pump is making a grinding sound so not sure if its on its last legs or not?
Cheers for all the Post All! :D
probably on its way out thats why i never restart jammed pumps but at what he charged you its not realy his fault id wait and see if the noise clears if not get him back to fit you a new pump as he sound cheap enough
Reply to Apollo Boiler keeps cutting out and making banging sound : ( Please Help I’m all cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi , I'm wondering whether anybody can help me at all ? My boiler has started making noises which I am unable to identify. If anybody is able to...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
C
Hello all, Like most people, I've gone to turn on my central heating after 6 months of it being off and, surprise surprise, it doesn't work. I'm...
1K
