  • Thread starter Ch4 plumbing
  • Start date
  • Replies 10
  • Views 2K
Discuss Aquatherm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Ch4 plumbing
Hi Guys
Has anyone used or been involved with this product? It has come up on a spec.
never seen it, is it specced for a reason or has the architect just copied someone elses spec to save time as they all do, I reckon one bloke did one initially and the rest just copied his spec
That's the kiddie, have you used it? any concerns or problems?
I would imagine the reason is cost compared to LCS (install time maybe not material cost)
It needs plenty of brackets as it will sag
Don't burn yourself too many times with the iron
I used it on site about 7 years ago was supposed to be the next best thing at the time.
Cant recall it being awkward other than a set time to make the weld ,one thing i do recall tho is that the bur from the pipe use to get into valves with filters.
We had a similar product over here.
Make sure you read the MI's for expansion loops !!!.
Make sure you test it to the correct pressures for a minimum of 24 hours.
It's good stuff, mark your weld depth cut the pipe straight. Start the fitting first weld the pipe for the right time, push the fitting and pipe together to your marked depth hold in place. Can't go wrong pal.
Reply to Aquatherm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
