Discuss Are 90mm pan cons for cast iron / clay? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Actually let me start over...
How would you sort this out.
The loo is wobbly because the base is cracked/shifting. The pan connector is leaking where it's going into soil, I'm thinking because wrong size i.e. crammed into too small a soil pipe? What would be the best thing to do? Would you have to replace the base? Or could you remove the base and re-do pan cons with some sort of straight connector / ofset / angled mallarcky set up...
I know I'm just talking to myself here so please excuse the stream of consciousness
I think I've chosen the right pan connector but it will need a plinth. What would you make plinth out of and could you get a decent cut shape and finish if all you have is a not especially good jigsaw?
whats the pan sitting on - it looks like a carefully shaped piece of toast (thick sliced)
toast lol. it looks like chipboard to me, use some wbp or marine ply.
I've got some 25mm marine ply. Two bits of that looks like right thickness.
But what do you reckon to a) my choice of pan con b) my chances of cutting the plinth to look ok with a jigsaw. How do you get that neat cut look?
Looks like a potential dogs dinner to me - but hey we have all been here. So
1. altering the cast will be really tricky and expensive
2. so take the wc all out and put a 'proper mulitquick' into the cast. that will get the seal.
3. build the pan up on a thick paving slab or floor tile no absorbant stuff
4. then use a long cheaper pan connecter
5. then get paid in cash
Centralheatking
Reply to Are 90mm pan cons for cast iron / clay? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
