Discuss Are radiator drain-offs now mandatory? in the Central Heating Forum area at PlumbersForums.net
My father is getting quotes to have his back-boiler replaced. The firm he wants to use have told him that they will have to fit drain-offs to every radiator as this is now required by regulations. Can anyone confirm that this is correct, and which regulation has changed to now require this?
You sure he’s not getting confused with trvs ? Drain offs are a nice thing to have and I use the ones built into a lockshield valve etc
Reply to Are radiator drain-offs now mandatory? in the Central Heating Forum area at PlumbersForums.net
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
I have had some old radiators replaced. Having checked the btu calculation myself, the new radiator is slightly undersized. It should have been...
Hi, My step daughter was ripped off by a cowboy builder so I’ve been helping her out and fittted her two radiator. I’ve no idea what is under some...
