Discuss Undersized radiator? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have had some old radiators replaced. Having checked the btu calculation myself, the new radiator is slightly undersized. It should have been 6150 btus, and the k1 rad that has been fitted (the required width in order to fit the old pipes) is 6025 btus. Output wise the next rad up would be a p+ which has a rating of 8367btus. Is the k1 rad ok, as the alternative is much bigger than required. Thoughts please!
I tend to fit over the odds , but new regs say fit as for ashp, you have trv"s fitted so you can dail down.
Reply to Undersized radiator? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a slightly undersized radiator in my living room. The calculation says 6315 btus and my rad is 6019 btus. It was a replacement radiator, the same size as the previous one (so pipes were in the right place). There is a gas fire in the room as well. Should this undersizing cause a problem...
have a mixture of radiators range between 25 & 60 years old.Im having a new boiler fitted, do I change all the rads or just the old ones? Cheers
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had an electric boiler which heated all the radiators just fine, but around a few years ago i had a gas one fitted and the radiators in the living and...
Hullo everyone its a while since I posted on here basically because i have had no plumbing issues however I have one now. My son recently moved into a house which has cellar within which is a radiator which is part of the central heating system. The rad looks old, rusty and horrible as does the...
Hi all. I noticed this winter my living room rad only get hot in the top half. Radiator is 1600mm(DP SC) double panel single convector. System was flushed just last year. Both flow and return values are fully open and don't stick. Boiler is serviced each year. Baxi combi boiler about 8 ton9...
