Discuss Armaflex lagging in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mfgs
Does anyone know which merchants stock armaflex lagging? Need to pick some up first thing tomorrow for a 32mm water main.
I have put it in rain water pipes with insulation before but just insulating is ok is it
Its underground but cant get it down to under 750 so need to lag it.
I see. What was the original size pipe and flow rate and pressure and what Is it with a 32mm main? Interesting to know for future. Also, did you get a small enough unvented cylinder for your last post
Existing is an old lead main, got about 18 ltrs/min at 2 bar. Got the 32mm main, and tws mainsboost plus accumulator going in so when its all up and running I will let you know. No I couldn't find an unvented to fit the space to had to get the architect to redesign the boiler and cylinder locations as they were optimistic at best.
Was the fat max too big?
It was a bit tight and really needed a 300 Litre as there is going to be 3 or possibly 4 bathrooms. The architect has redesigned it now and come up with another location in which a standard 300Litre cylinder will fit so I am happy.
AF/Armaflex class 0 with tuff coat R protection. Screwfix.
Reply to Armaflex lagging in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
