Discuss Awkward toilet location in the USA area at PlumbersForums.net
Hi, I have got my toilet waste right in front of a gas pipe I can’t move. I can’t get it to fit as it is off set. What fitting should I use to make it fit?
Something like
https://www.NoLinkingToThis/p/mcalpine-wc-con8f-90-flexible-pan-connector-white-110mm/28262
Something like
Prefer solid pipe over flexi if possible myself. seen too many flexi`s attacked by rodents.
Reply to Awkward toilet location in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
