Discuss Back in stock: March 2015 PORSADRILL box sets the "Essential" drills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
365drills
We WERE out of stock but great news as of Feb 2015 we have made a new batch of these.
BACK IN STOCK
http://www.*********.com/boxset/ESS1.jpg
http://www.*********.com/jpgs/guideplate.jpg
Back in stock as of March 2015 (3rd March)
12 Diamond cores perfect for essential UK and international pipe sizes. Plus your fixtures and fittings.
What's included in this 1KG boxset ?
What is it ?What is it used for ?
4 x 6mm For Red Rawl plugs and small fixings...... http://www.*********.com/jpgs/redplug.jpg
4 x 8mmFor Brown Rawl plugs for heavy duty fixings..... http://www.*********.com/jpgs/redplug2.jpg
1 x 18mm15mm pipework, copper, plastic, water feeds, fisher fitting kits, rad pipes
1 x 25mm22mm pipework,
1 x 35mmMonoblock taps, Shower rose, Body Jets.32mm waste pipe for a sink. 28mm gas pipes.
1 x 45mmLarge waste pipes for baths. Example 40mm (ID) waste pipe for a bath or shower - Push Button flush
1 x Water Sponge To cool the diamond cores consistently and collect dust
1 x J-Hook To remove (eject) the tile from inside the cores perfect on small sizes
1 x Main Guide PlateAnti slip guide for the small sizes of 6mm and 8mm
1 x 18mm Guide PlateAnti slip guide for the 18mm (this size is in the 25 35 and 45 plate)
1 x 25mm Guide PlateAnti slip guide for the 25mm. Also has other sizes on the plate.
1 x 35mm Guide Plate Anti slip guide for the 35mm. Also has other sizes on the plate.
1 x 45mm Guide PlateAnti slip guide for the 45mm. Also has other sizes on the plate.
1 x heavy duty case Keep all your diamond cores together. Easy to spot colour.
Wow !
The most essential set we have ever sold !
£190 if purchased separately !
What is the item / size?
What is the price if bought outside of the kit
4 x 6mm £30
4 x 8mm£30
1 x 18mm£15
1 x 25mm£20
1 x 35mm£35
1 x 45mm£38
1 x Water Sponge £2
1 x J-Hook £5
1 x Set of 4 guide plates£15
1 x heavy duty caseKeep all your diamond cores together. Easy to spot colour.
£190 if bought separate
The Cost of the separate items would come to £190
LIMITED EDITION PRICE:
[SIZE=+3]£190 ? £175 ? £150 ? £135 ? £125 ? £115 ? [/SIZE]
Better than half price deal !
http://www.*********.com/boxset/crazy.jpg
TAKE A LOOK AT THE WEBSITE TO SEE WHAT PRICE THESE ARE RUSHING OUT THE DOOR AT...
Richard, excuse my technical ignorance but where am I looking on the website for the price of this item??
If you are looking at the box sets there are two pages to choose from
1) The ESSENTIAL (small set)
2) The ULTIMATE (large set)
Here are the page codes:
1) ESSENTIAL -[DLMURL="http://*********.com/essential.htm"] CLICK HERE [/DLMURL]
2) ULTIMATE - [DLMURL="http://www.*********.com/ultimate.htm"]CLICK HERE[/DLMURL]
Each set offers something different for installers. And you simply have to select the one that suits your long term or short term needs the best.
http://*********.com/boxset/ESS21.jpg
Met Richard at the FFX tool show on Friday and watched his demonstration, instantly brought the bathroom fitters kit (will upgrade to larger set). An absolute must for anyone drilling tilings!
Hi Richard
do you need to know if we're a forum member when we order??
Hi thanks for the comment. Simply go ahead and order and you will be the proud owner of a 30 piece box set or a 12 piece box set.
Just a general reminder the clam shell kits (not the box sets) are available retail from Williams Plumbers. So anyone who needs the 7 piece set can either order online or go into any Williams Branch.
Note Williams is TRADE ONLY - No Public.
http://www.*********.com/jpgs/kit2.jpg
The seven piece sets are available from Williams Plumbing - Or online from the ********* factory.
http://www.*********.com/boxset/bothsets.jpg
The cases (either one) are not available retail They are only available online - factory direct.
Reply to Back in stock: March 2015 PORSADRILL box sets the "Essential" drills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
