Discuss back to wall toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sws
Hi again - following all the useful advice previously, I'm going to go with a back to wall toilet / concealed cistern.
Is it possible to install these temporarily until I get the tiling done. I'm just aware that the floor tiles will raise floor level a bit, so if I plumb it in before the tiler does his bit, the flush pipe/waste will no longer line up. If I wait until after the tiler, I won't have access as he'll be tiling behind the toilet, so access will only be from above the cistern.
I supose I can use a flexi waste connecter, but will the flush pipe have enough adjustment to allow for the change in floor height? I assume the concealed cisterns have adjustable flush pipes which are cut to length (or is that incorrect)
If its a floor standing pan you could put it on a rasied a board same thickeness as floor make up and same for behind for the tile make up then just removed a tile as normal when ready.
Thanks. I assume if there's a problem, flush pipes are interchangeable anyway? so for a fiver could change that- am I correct?
Is there generally a few mm 'give' anyway in these or do they need to be spot on?
sws
Reply to back to wall toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
