Sorry for my ignorance but not being a plumber...what are the consequences or issues with a gatve valve on unvented system....is it a safety thing?
Sorry I am being unfair, there is no safety issue using gate valves on an unvented system, and many plumbers still use them
I have found through experiance that gate valves used on unvented systems tend to let water through the gate when you are using these valves to try isolate somthing so then you try to shut the valve even tighter and invariably you end up snapping the spindle, this means that the whole valve then needs replacing.
I prefer using full flow ball lever valves, and you will find that these are usually more expensive than gate valves
