Discuss Balanced compartment boilerhouse in the Gas Engineers Forum area at PlumbersForums.net
I have a balanced compartment boiler house, fitted with 3 forced draught open flued boilers, is this acceptable?
Don't have access to ige/up/10 to double check, and the literature I do have is very light on the subject.
Thank you.
Where’s the combustion air coming from ?
And the vents allow enough air for combustion and cooling etc ?
Eg net x 10 cm2
Fine providing the vents are clear eg 600mm and the room is sealed so inspect door seals etc it’s good they’ve got a interlock on the door
Thank you for your help,
someone has cut air vents low level in the doors (2 years ago, which the installation is 24 years old)
which i believe is effecting the combustion of the boilers.
I highlighted this issue, to which I'm being dragged over the coals "as it isn't a balanced compartment" as "you cant have forced draft burners in a balanced compartment" referencing igem documents he knows I don't have access to.
But my onsite reference books and British standards don't mention it.
Many thanks 😊 🙏
Send me your email will send you up 10 over
Reply to Balanced compartment boilerhouse in the Gas Engineers Forum area at PlumbersForums.net
PSxxxxxx
