Discuss Base unit removal, unsure what to do about this block in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi
I need to pull out a drawer base unit from my bathroom, not fitted by me.
I have removed most screws but I am faced with one of these in each top corner inside the unit, which I belive are called wall bracket hangers.
There is screw as pictured, then another single screw underneath.
The unit has a counter top above it.
What do I need to do with this screw please?
Am I right in thinking it will lift a latch to a rail behind the unit?
I cant see whats behind as the unit has a backing.
Many thanks
Tbh you may need to remove the worktop or cut a hole in the back so you can lift the arm off the wall plate
Reply to Base unit removal, unsure what to do about this block in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
