Discuss Base unit removal, unsure what to do about this block in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi
I need to pull out a drawer base unit from my bathroom, not fitted by me.
I have removed most screws but I am faced with one of these in each top corner inside the unit, which I belive are called wall bracket hangers.
There is screw as pictured, then another single screw underneath.
The unit has a counter top above it.
What do I need to do with this screw please?
Am I right in thinking it will lift a latch to a rail behind the unit?
I cant see whats behind as the unit has a backing.
Many thanks
Tbh you may need to remove the worktop or cut a hole in the back so you can lift the arm off the wall plate
Reply to Base unit removal, unsure what to do about this block in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
Hi. I have a kitchen mixer tap unit with older washer type inserts which has a dripping cold side. I have a pair of replacement ceramic inserts to...
Units involved: Gainsborough 10.5SE heater unit with Swirl (Screwfix 278PG) overhead shower kit with diverter. Hi guys. I have a Gainsborough...
Hi folks, sorry to have to post this but we got a new bathroom a few months ago and the toilet seat was loose at one side. The cistern is...
