Discuss Basic duo tec 24he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
giarc00007
Just installed above boiler with vertical flue. Getting explosive ignition when first ignites (not excessive but noticeable) but all checks spot on 19 mbar working pressure. Analyser readings fine. I know these are prone to probes. But this is new install.
Isn't there an issue with an injector on these? Or am I thinking of another boiler.
Either way make sure what you've done is bob on, gas rates, flue etc, then call Baxi out.
I think you are thinking of the Ideal Logic with regards to the injector issue
gas rate spot on checked 3 times. flue all spot on. 2 x 45's, 2 x extension and 1 terminal supported at 3 points. Will check electrodes tomorrow but surely will be fine. Cant think what else could be. Is it more common with verticals for this type of thing?
If you getting explosive ignition it's gotta be opening too early, thus building up gas. If it was late, prob just get ign lockout.
Do as Ermi has said and say no heat and hot water, say you have had to turn it off or whatever to make them come before Xmas!!
thanks aquazone will do.
Might just be sloppy, Venturi in mess. If your all 100% then boiler should be so don't let heat monkeys fob u off or leave without fixing it . You want it fixed or replaced.
Reply to Basic duo tec 24he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I...
Good morning all, just a quick one here and i was wondering if someone could give a little advice on their own experience. I don't usually do a...
H
Hi! If anyone is able to give any advice it's hugely appreciated! I'm in the UK if that makes a difference. I have a condensing combi boiler...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
B
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
B
