What are your readings (ratio,CO and CO2) on min, and max?
Have you put your fga into the air inlet test point?
Could be a million and 1 reasons for it kicking the case on ignition. Excessive standing pressure (meter reg not locking up),electrodes,ignition gen,condition of burner and insulation panel,gas valve,air signal tube onto gas valve,flue,flue seals
When I was with heateam this was quite a common call out, it's usually incorrectly set gas valve, ensure min is 8.4% +- 0.2% and max 8.7% +- 0.2%. Will usually require adjustment for a vert or complex flue due to the additional resistance effecting the pressures
