Discuss Basic duo tec 24he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Might just be sloppy, Venturi in mess. If your all 100% then boiler should be so don't let heat monkeys fob u off or leave without fixing it . You want it fixed or replaced.
will phone tomorrow just looks bad when ive recommended boiler to customer and already getting baxi out. but checked
everything and installation fine.
Just explain its working fine just its a bit noisy and you want it sorted as u don't want them to find it annoyance.
my last duo i installed made a horrendous noise the first time i fired it up, but then seemed to be fine. Customer rang me back 2 days later saying she could smell gas by the boiler so i flew out there and no signs of gas but the boiler stank really bad. Real sort of eggy smell.
Called heateam out and they couldnt find anything wrong with it and left .. luckilly the smell went away and i put it down to "newness" .. kind of put me off baxi a little
I commissioned one the other day, some smoke was coming off it. They tend to spray and light dusting of oil on metal products, so they don't corrode whilst in storage. I remember fitting a balanced flue gas fire a few years ago, it set all the smoke alarms off in the house! Nothing on the fga though. In the instructions manual, it actually warned that smoke alarms would probably go off on first use.
What are your readings (ratio,CO and CO2) on min, and max?
Have you put your fga into the air inlet test point?
Could be a million and 1 reasons for it kicking the case on ignition. Excessive standing pressure (meter reg not locking up),electrodes,ignition gen,condition of burner and insulation panel,gas valve,air signal tube onto gas valve,flue,flue seals
When I was with heateam this was quite a common call out, it's usually incorrectly set gas valve, ensure min is 8.4% +- 0.2% and max 8.7% +- 0.2%. Will usually require adjustment for a vert or complex flue due to the additional resistance effecting the pressures
thanks for input dmheat. ratio as far as can remember was 0.0009. standing pressure 24mbar working 19 mbar. checked air intake 20.6.
Keep us posted on findings mate ,
I had a failed tightness test on a new build on the site were at , turned out the gas valve was passing , it just seems that were having too too many issues on brand new boilers , and it looks bad on us to the customer especially if we advised them on the brand in the first place,,
Reply to Basic duo tec 24he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I...
Good morning all, just a quick one here and i was wondering if someone could give a little advice on their own experience. I don't usually do a...
H
Hi! If anyone is able to give any advice it's hugely appreciated! I'm in the UK if that makes a difference. I have a condensing combi boiler...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
B
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
B
