Discuss Basic question - pex or copper for self build 100 sqm metre in the USA area at PlumbersForums.net
Basic question - pex or copper for self build 100 sqm metre 2 story house.
It Is a budget build but will form part of a larger house for years to come.
Plan to do some basic plumbing myself, no gas or oil just water pipes.
which is a better option and why.
Thank you
Mlcp or copper for me
Mlcp has a 25 year warranty depending on manufacturers but copper is always best depending on your skill level
I'm old school and prefer copper.
I also recommend you get a quote from a professional for the work before going down the DIY route. For a reasonable sized job it may be less than you expect. I don't know about Ireland, but in the UK you'll need a pro to do the interesting stuff (boiler, unvented hot water, etc.) in any event. Also, if you ever plan to get rid of the place 'DIY plumbing throughout' is not a positive selling-point and may impact the value.
Thanks! Will get the quotes too and plumbing oversight if I go diy on the basics. Good advice thanks!
Reply to Basic question - pex or copper for self build 100 sqm metre in the USA area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
