Discuss Basic two pipe system for my 3 rad narrowboat heating install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
I have a diesel water heater to install into a narrowboat i am currently fitting out.
Which heating layout would be better?
I have been advised on a two pipe reverse return plumbing layout rather than a direct return?
Here are some basic diagrams I drew up
I have also put a manual tap after the T piece to be able to just have the hot water tank - is this ok, there is no 240v for a electric valve?
Also what pipe sizes would be recommended?
2 Pipe Direct Return
Appreciate any advice in advance
Mitch
Use a 12v normally closed relay then! And yes reverse return good. Hope you've got a water cooled genny and engine your using to heat your heating!
what s the out put of the heater if its just a small webasto or eberspacher i would think it can all be done in 15mm
Its a 5kw eberspacher - is there any down sides of using 15mm over 22mm? If not may aswell use the 15??
p.s thanks for the replys.
mitch
22 better delivery lowerd pump head but u probably be ok with 15 or even 10
Sisters running 22mm off coal fire & back burner on her boat and know of an diesel eberspacher with 15mm on a 70ft boat.
Got a feeling Canalboat.co.uk covered this earlier this year, might be worth a look.
Reply to Basic two pipe system for my 3 rad narrowboat heating install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
