Discuss Bath fittings supplied in the USA area at PlumbersForums.net
Hi all, I’m currently having ago at fitting a bath. I was supplied with some fittings I cannot figure out what to do with them. I think the larger white pice is perhaps for fixing the bath to the wall. Has anyone used these fittings? If so how do they work. Thanks for having a look.
Did you not get fitting instructions?
Reply to Bath fittings supplied in the USA area at PlumbersForums.net
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly...
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
1K
Hi, I’m having a gas cooker pipe capped off. The GS registered plumber/ fitter, has told me that to do this, he’ll also have to service the combi...
