Discuss Bath mixer tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I have a problemwith the hot water from my bath tap. Thetap is a mixer type and the cold water works fine. I’m also getting hot/cold water from thesink.
I’m not sure whatthe problem is, i.e. does the tap need replacing or the does the spindle needreplacing. Can anyone advise me?
I’ve been quotedaround £40 by a plumber to replace the bath taps, but this is almost half adays wages for me so I want to try and tackle myself.
Thank you.
Coud be the washer, could be the guts have failed.
40 to swap bath taps, snap his arm off.
Can you post a picture of the tap? Could be a variety of things depending on the type of tap.
Reply to Bath mixer tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
