Discuss Bath panel fitting problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jiffter
I've just bought a bath and ready to install it. The bath panel needs to be fitted but there are cardboard tubes in each corner. I need to remove two of these tubes to get the panel to fit properly. Is it okay to remove them or are they there as strengtheners?
Many thanks in advance.
Hi Jiffter.
If they are made from cardboard they are just there to protect in transit.
For a good sturdy fitting for bath panel,try and fix a baton frame up both sides and across the floor. You can then screw to this using srew covers for a good finish.
Many thanks for that. I thought that's probably what they were for.
Reply to Bath panel fitting problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just...
