Discuss Bath/shower mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jmcclintock77
I've fitted a bath shower mixer with the chrome elbows connected to the water supply leaving them on the bath to screw the tap onto by 22mm nuts. I've put ptfe tape on the elbows but cannot get them to stop leaking (very slight drip) if I over tighten them they leak more. Any suggestions, totally stuck. I've put a link below of the tap in case I don't make sense
In anticipation
James
http://www.victoriaplumb.com/images...tic-Bath-Shower-Mixer-surface-mounted_942.jpg
Hi was the tap not supplied with washers? regards turnpin:cheesy:
Only to fit the elbows to the bath. The connection of the 22mm nuts has a mesh inside but no washer
I think you need some washers normally supplied with tap contact your supplier or pop into a local merchants with some pics on your phone and they will sort your problem for a small fee regards turnpin:cheesy:
Thank you. I'll give it a bash. Is it a fibre washer rather than rubber for any reason?
Thank you!
Reply to Bath/shower mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I have Charlton Mixer Tap in my shower i.e. thermostat and water control. I need to change the cartridge in the tap as it is dripping badly...
So recently we had a shower with exposed pipes and I decided to sink the pipes into the wall, Ive completed that task only to find I havent sank...
1K
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hi there I connected a new shower wand which has a chrome outlet back into a 4" inch thin wide wall and comes out to a 1/2 inch male. I put a...
I have a grohe 800 bath/shower mixer and Grohe pillars to deck mount them but am unsure about the washers. The taps come with the brown fibre type...
