Discuss Bath waste/plug issue? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
macka09
Hi all
Do any of you guys use a silicone to seal between the bath and waste rubber underneath?
The bath is only a cheap one and the bottom of the waste opening isn’t flat, which seems to leave an opening enabling water to leak out.
I used silicone in the past for this very problem but I was curious as to whether there’s a better alternative?
Cheers folks
Depends I normally give it a skim of silicon or get the grinder out with a sander
Reply to Bath waste/plug issue? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Afternoon, our bath waste pipe in our rented property has started leaking slightly when we shower. We've narrowed it down to a loose screw in the...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
In my last posting, I requested assistance in exchanging a waste that had been fitted using silicone, without actually removing the basin. Mission...
Me again. This turning out to be a nightmare from hell this bathroom. Your help do far has been invaluable. So, the next issue is one that I may...
