Discuss Bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pauls
customer has bought a new bathroom suite from b&q the old bath i measured and is 166cm new bath is standard size 170cm i know i will have to chase it in by 4cm ish, seems a lot to chase in i cant chase in from the tap end for obvioues reasons any ideas.
mac a do from knock adoo if it wont fit make it doo :)
can you not chase the opposite side of the bath dude>?
yes thought of that but bont want to loose to much at tap end, i am playing on the idea of going 20mm ish each end and hopefully this will still give me enough room to get the taps on.
Are the tap holes pre-drilled? Alot of baths these days you drill your own holes
i cant remember looking now:eek: if they are not then i think this will give me an advantage as i might be able to squeeze a few more mm if not then bugger:D
Reply to Bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
1K
