Discuss Bathroom towel rails? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm planning a bathroom remodel and wanted to replace my existing bathroom rad (will be too small and cast iron) with a towel rail and worked out I need something in the region of 1200w, am I being dense the largest towel rail I can find is only half that power rating? For the space I have (approx 600mm wide & behind door) standard rads aren't really tall enough, can you recommend any other options? Thanks in advance.
Towel rails have low outputs because thats what it is!!! A towel rail
Look for the tall expensive designer rads :)
i agree, to get the output equivalent of a normal radiator you would need to get a ginormous towel rad. one way to maximise heat would be to not fit a trv to it.
if you want a towel radiator i would get underfloor electric heating if your tiling the floor
Have a look at somewhere like Best Bathrooms.There are some tall thin designer rads. which offer the required output.You would need to be aware of possible issues when the door opens as often these can protrude further from the wall.Prices £120 upwards.The other obvious issue,they are not suitable for towels!! I have a small rad. in small space at end of bath + towel rad.,always pleasantly warm.
One thing worth looking at is having a white rail instead of a Chrome one. Chrome plating a rail reduces its heat output quite sharply.
Ooooh check out the cunning merchant who has 200 white 600x1200 white towel rails from 96'. Good point tho.
As cunning as a fox with a degree from the university of cunning? Black adder a classic
Thanks for the ideas guys...found a tall column rad I quite like and going to couple it with a small towel rail, that should match my btu requirement.
Towel rails don't give off much heat when covered in towels!
good decision.
White are nicer too. We have a chrome one but I wouldn't get one again - speaking as NOT-a-Domestic-Goddess - chrome takes a lot of looking after on a daily basis to keep it looking shiny.
I would also go for the electric UFH as suggested above.
Reply to Bathroom towel rails? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
