Discuss Baxi 100HE banging noise? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
alastair
My first post! Im a plumber from poole just gone self employed and starting out....
First problem is this BAXI 100HE I changed the door seals on it last year as it was locking out after testing found it was triping internal switch... changed it and was fine. Now its started to make a massive bang when firing up and occasionally locking out.
Does anybody have any experience with these would be very grateful?
Al
Check the burner mating is not damaged,its getting old and this is a not un common fault,new burner will be required if so
Reply to Baxi 100HE banging noise? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I wanted to start a new more dedicated thread as I am on about 3 just now in one way or another trying to get up to speed with my problem. The...
2K
Hi. We’ve had rather a lot of noise issues with our radiators since we had a new boiler installed. Our radiators other than 2 more recent ones...
6K
I have a Baxi Duo Tec , fitted 10 years ago. No real problems until very recently. My plumber has serviced it every year and most recently two...
4K
I have a standard open vented system. I recently replaced a radiator and took the opportunity to drain the system and refill with fresh Fernox...
1K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
