Discuss baxi 105e in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gymdad
just changed expansion vessel and prv to solve an increase of pressure, filling loop not by passing but pressure is still increasing even c/h is off could this be main heat exchanger
if you have ruled out ev,prv,and filling loop your plate heats pinholed
Turn off cold feed to boiler, if pressure stops increasing then gas man is probably right, plate to plate pin holed.
Either the plate to plate has pinholed or the pipe coming out of the bottom of the expansion vessel is blocked (quite common)
If the pipe is blocked, the prv normally blows off. water has no where else to go.
yes it will... eventually, but it will eventually if the plate to plate pinholes, changed one 2 days ago for same thing. It doesn't have to be a catastrophic blow off, it sometimes releases as a constant slow flow / drip
Reply to baxi 105e in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
