Discuss Baxi Bermuda to Combi change. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Are you doing the job without them knowing what it will cost or what they are getting?
Most people want to know the ins and outs of a cats arse
If its a budget job give them the 24 and 28/30 as an option, cant blame you then if the hot water isnt as good as they hoped
havent you give them a price esp as your doing it this sat and your buying materials
Thanks for all the replies, ordering materials tomorrow.
Not a massive job I know and for most here it would be a doddle but it's the biggest job I have quoted and booked in myself. Looking forward to it, don't expect it to be plain sailing as it's an old system I'm connecting on to. Will get pics before and after.
I'm calling him in 30 mins, I gave him a rough price verbally Sunday, he said fine. Will collect deposit Friday.
What would you charge from the info I have given just so I can see if I'm on the right lines.
were normally top but conversion
min 1200 i would put 1600 labour
600 - 800 materials
1200 -1400 boiler flue clock mag etc
new rads 600 - 1200
its a poke in the dark without pricing it up myself
When we spoke on the weekend he said he will leave it to me, already given me the key to go in and start Saturday. He's an old guy, very laid back. Done a few jobs for him, concealed shower and a few other small jobs. Always been fair with the price and he knows it.
Last thing he said was oh well it needs dong so I'll let you decide what's best. I'm speaking to him shortly just to confirm everything.
2 days might be a bit of a push to get it fully done. I allow 3 for a back boiler to combi conversion, normally lose a full day on the system flush and commissioning.
600 - 800 materials
new rads 600 - 1200
Im not doing rads, even though I've advised new system he has said just do the boiler for now and deal with any issues after.
fair enough still the same as will need a good flush
I agree 2 days will be a slog. Truthfully I'm expecting to be back Monday.
3-4 days min
They are a slog BBU to combi converisons,
But I do find them very satisfying to do as they can be a challenge sometimes and you dont know what little issues previous installer has thrown in.
The only thing I'm wary of is the current set up is the back boiler does heating only. How comes off a cylinder with immersion.
Is this common?
Is this common?
Is this common?
will be a common cylinder i think heating and hot water use the same water
Is this common?
Are you 100% ?
Is the cylinder, square shaped?
Yes.
It's this
But the coil is not connected. Boiler only does ch.
Job completed, went well.
Saturday, removed wall unit, hung stand off kit and cored hole. Ran pipes in to loft. Decided to run all of them up as the cylinder was in the loft and the cupboard with the meter was accessible going through the ceiling so made sense. Lost time coreing the hole, think it's time for a better drill mine is on the way out and made it really hard work.
Ran hot and colds to where they needed to be and left them ready to connect Sunday so I could leave the tenant with hot water. 11 hours.
Sunday removed pump and flow and returns in living room, replaced and reconnected with new pipe. Vents fitted in loft. F and R run across loft. Gas pipe renewed and TT. Cylinder drained, H and C connected in loft. Electrics run in mini trunking around kitchen. (Most of the sockets in the flat are surface). Flue out. Timer on. Up and running 9.30 pm. 13 hours.
Back yesterday, flushed, commissioned, removed back boiler, tidied up. Paid. 6 hours.
Cold feed was blocked where I suspected.
Hardest flue hole I've cored yet
Looks like you might have gone through the lintel
Also any more pics ?
Reply to Baxi Bermuda to Combi change. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
