Discuss Baxi duo tec combi problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
3083sam
I've got a baxi duotec combi and when i run the hot water, the temp guage shoots right up, then there is a clunking noise in the boiler, no error codes are coming up. The pressure guage is also shootin up and down but when the boiler cuts out the guage stabilises. Its obviously overheating.. Any ideas anyone??
Does it shoot up straight away?
Blocked secondary heat exchanger or failed pump are my first two thoughts.
If the plate hex was blocked wouldn't he hw come out Luke warm?
sounds like you need a gas registered engineer to sort your boiler. not being cranky or sarcy but it is not what you obviousley think it is
I am actually a gas safe registered engineer, just wasnt to sure what it was, technical are closed on a sunday so thought i would ask on here..
The heating side works fine, only on the hot water side. Thought it might be a stat..
i think I'd be inclined to agree with all those who're thinking the dhex is a likely culprit.
Reply to Baxi duo tec combi problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
