Discuss baxi duotec 1/hea/plat/heatmax/promax/gold/titanium fault codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Billy Bob Bob
Code NumberDescriptionCommentGuidance in Installation InstructionsAdditional Checks Before PCB Swap● Check Gas supply and flue system correct (including condensate) .● Check connection between Gas Valve and PCB (large clear 9 wire connector).● Check connection between Spark Generator and PCB (grey 4 wire connector).● Check connections between Spark Generator and Electrode.● Check Black Sensing Lead connection between Electrode & PCB (connects to the left hand side of PCB at the bottom)E151BMU Internal ErrorShould not see, PCB errorNo● Hold Reset (ON / OFF Switch anti-clockwise) for 5 seconds. If doesn’t reset replace PCB.E152Parameter Setting ErrorShould not see, PCB errorNo● Hold Reset (ON / OFF Switch anti-clockwise) for 5 seconds. If doesn’t reset replace PCB.E155Remote Reset OffShould not see, PCB errorNo● Hold Reset (ON / OFF Switch anti-clockwise) for 5 seconds. If doesn’t reset replace PCB.E160Fan Speed Threshold Not ReachedFan System FaultYes● Check connection between Fan and PCB (small black connector with on right & grey 4 wire connector)E161Maximum Fan Speed ExceededFan System FaultNo● Check connection between Fan and PCB (small black connector with on right & grey 4 wire connector)● Check System pressure● Check Pump Operation● Check Connections to X400 and pressure sensorE167Heating Power Limit Exceeded / Under-runShould not see, PCB errorNo● Hold Reset (ON / OFF Switch anti-clockwise) for 5 seconds. If doesn’t reset replace PCB.E164Flow/Pressure Switch Heating Circuit ErrorCirculation Fault Primary CircuitNoPCB Error Codes For Stainless Steel Heat Exchanger AppliancesE133Safety time For Flame Establishment ExceededFlame failure
Reply to baxi duotec 1/hea/plat/heatmax/promax/gold/titanium fault codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, My mum has a Worcester Greenstar HE30 boiler (15+ years old). Since its last service (and possibly coincidentally) it has been making a...
2K
N
Hi All I know I know ... another HE24 LF code problem. Fix is replace boiler ;-) My problem is slightly different to other posts I've been...
3K
Mikesin
M
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Hi Everyone, Potterton gold Heat only driving me mad, would appreciate if anyone has any ideas on this one as boiler cutting out after 10-15secs...
Burger
Hi all, I have read several posts and searched the internet and believe I have now got the correct procedure to install a Nest for my Greenstar...
4K
