Discuss Baxi duotec E133 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stani
Subscribed
I have tried searching for threads regarding this fault but keep coming up with closed threads, can anyone point me in the right direction with this appliance, it's my bosses old house which he now let's, don't normally do faults but because it's his ,he sent me out.
cheers Stani
E133 - Failure to ignite - On older models built pre 2010, the ignition electrodes warp with the heat. They are now re-designed and much better. As a temporary fix, bend them back to make the gap the thickness of a pound coin. put a blow torch on first or they will snap off!
If its the electrodes warping, which I have had a number of times, the boiler often goes to lockout when it re starts after being on for some time.
Is this the fault code that can mean anything ? Could be water in diverter motor, electrodes, spark generator, PCB, all it means is boiler doesn't work
When I arrived the boiler had been running then gone to lockout again, hopefully new electrodes may do it.
Thanks to all for the replies much appreciated.
Stani.
Stani.
try bending old ones first with heat.
if they snap then get new ones anyway but it might solve diagnosis.
Reply to Baxi duotec E133 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has...
Good evening, Wondering if i could get a little guidance, I have a 3/8 plastic line running from a softener to a coffee machine (because...
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
