Currently reading:
Baxi fire front compatability
Discuss Baxi fire front compatability in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Baxi 552 back boiler,don't laugh but because it's been so good I want to keep as long as poss. My gas guy has told me i now need a replacement fire front so I am looking out for one.As I understand there are two fronts for this boiler one with ceramic radiants which is mine and one with coals and a glass front.Will the latter one fit mine without any modification.Thank you
So are we .
We can’t recommend buying a second hand fire front, to an already very old boiler.
OP: Be careful, as fires that fit the 401, the 551 and the 552 will look similar - but are not compatible. Only use a fire that has come off the same model. You are likely to need a new connector as well, but the RGI should be able to sort that out.
As I have been (IMO, extroadinarilty) edited, I will rephrase it:
OP: provided all is done safely, there is nothing wrong with using an old fire or boiler. Whwn Chalked says "We" it should not be taken, categorically, as referring to a greater number of professionals than himself
I suppose in a ideal world I should just replace the the whole system but am a pensioner who just hasn't that sort of cash.There seems to be a bit of can, can't, shouldn't really opinions, which is a bit confusing but if I am understanding correctly, i can replace the fire with a like for like and would also be able to use the other type of fire as long as it came off a 552 (which it has).If this is not the case I will just look for an excact replacement.Thank you for taking the time to advise me, my GS fitter is on holiday so can't ask him directly at present.
If I had the correct fire in front of me . I would fit it. But “we” means the general forum advice ,given to a poster, who we have no idea if he has the correct fire or not.
TBF, this is the problem to which Chalky eludes. I gave, IMO, safe advice. You have slightly ignored it. Your "exact replacemet" may not be an "exact replacement", hence my caution that you only go for a fire (irrespective of the model) that originated from a 552.
Here you go.
Reply to Baxi fire front compatability in the Plumbing Jobs | The Job-board area at PlumbersForums.net
