Discuss baxi solo pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
carrpaul
hi there can the baxi solo be wired to let the pump over run . i think i got told a while ago there was a kit available
I thought the pump over run was to take excessive heat away from the boiler after shut down?
Are you talking about the HE Solo or PF 2/3..If the HE has a lot of carp in the bottom of the heat ex then when it shuts down the residual heat can sometimes give O/H lock-out. 240340 is the number of pump over - run kit.
good point poxi,both called solo but different boilers 1 works 1 dont
hi there just that am putting towle rail on to primary pipework , thought i could just use the facility , but looking in boiler book no over run for my system
hi there dose any one know how to wire pump overrun on baxi solo 12 he as boiler only has switch live ??
thanks for reply , so how dose p l on boiler do any thing different to connecting to orange
its too late for me to guess TBH,and even though baxi make the best combis i dont fit there heat only as there tat ,but pm a member on here called poxi,he works for them and as long as you ask nicely should be able to help
Reply to baxi solo pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if...
PSxxxxxx
