Discuss Baxi System 100 HE Plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
coylumbridge
We installed a Baxi System 100 HE Plus condensing boiler into a new closed system nearly 5 years ago. It gets serviced annually yet breaks down at least once or twice per annum, ie pressing the reset button won't restart it.
Wondered if anyone also has experienced problems with this boiler please ?
Cheers
I fitted 5 of these 5 years ago to a block of 5 new build town houses., 1 has been a pain in the arse, 2 have had 1 cheapish repairs each.So luck of the draw I suppose.
thanks blackcat - no difference from buying a car then
cheers :rolleyes:
Reply to Baxi System 100 HE Plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I’m having a problem with my Baxi combi boiler and wondering if anyone is able to help. In short, the water isn't heating. A few months...
1K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
1K
H
HRP123
H
Hi, wondering if any of you have come across a gun type oil burner that needs reset every time the thermostat shuts it off? What can cause this? I...
1K
Hi everyone, I 'think' I've found a cheap solution to fulfilling all of my family's heat automation needs using Terrier i30 TRVs (eTRVs that have...
1K
Deleted member 120897
