Discuss Baxi system boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
CadMonkey
Apologies if this is posted to the wrong forum. I have a Baxi Solo HE system boiler, which constantly goes into fault mode, boiler will start up just fine, but once the system reaches steady state, boiler goes into fault mode when the thermostat calls for more heat. actually boiler ignites then after a fraction of a second, the gas valve closes again, the process cycles round several times, then the boiler goes into fault mode...is that a common problem?...I thought maybe the flame sensor was shutting off the gas valve when it shouldn't, but I dunno...I'm not a plumber...appreciate any suggestions...Thanks for reading
Unfortunately we can't offer you any advice apart from contact a gas safe engineer or if you don't know anyone post it on this forum and someone may be near to you
Reply to Baxi system boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
