Discuss benchmark in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
How many of you come across benchmarks that are not filled out? I have assumed it's an uncommisioned appliance if this is the case but more often than not I find out its been installed by a gsr company and has been signed off and has a notification.
So does a non completed benchmark make it commissioned?
If you carry out all the tests then it's commissioned, not filling out the paperwork is part of the "full process" and doesn't comply with the MI which usually ask for them to be completed, however it's worse when you find them filled out with exactly the pressures and values straight from the MI without the checks being done, same as service work, used to see loads of CP1's stating BP as 10.7mb, when most people use a water gauge it's impossible to record .7 on a gauge, and funnily enough the MI state 10.7mb
This is why the benchmark has been implamented.
I hate it when you come across ones that are half filled out with only the standard parts filled out.
ie what cleanser used . - 1 litre x300
Hot water gas rate -- blank
CH gas rate -- blank
Hot water flow-- 14lpm
Checked at all outlets - not a chance
See loads of it these days wasn't sure what the interpretation of a blank benchmark is
did a service the other day.
bench mark was all filled out, a bit worried with the recorded gas rating something like 3.3m/h
it was only an 18kw system,
interesting that the manual covered a couple of different sized models,
no prizes for guessing where the figure came from.
in 8 months on social housing im yet to see a bench mark book left with any boilers and ive serviced some only 3 months old
When my mate had his system done I called round in the afternoon waited till they left and had a look over everything and surprise surprise no benchmark
you reminded me of a boiler I serviced last year. The benchmark was filled out with a gas rate of 5.8. I thought it was strange until I realised it was the heating and hot water figures added together. It also had a flexible tap con as a filling loop. :(
Reply to benchmark in the Plumbing Jobs | The Job-board area at PlumbersForums.net
