Discuss Benchmark in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kainedog
Hi lads , first time on here , hope you're not working too hard !! Right my landlady ( nice woman ) called me the other day as she's had a loft conversion and has a system switched over to a combi and that she's not been able to switch the heating on and off as no Roomstat installed !! I said I'd have a look , it's a Worcester and it's been in for 5 weeks but the benchmark has not been filled out , I told her a) I'm not touching it till it has and b) that who ever installed it should have fitted a room stat pretty much straight away . The plumber has since returned and fitted the Roomstat and partially filled out the benchmark , he has not analysed the boiler or left any printouts or done any gas rates , he told her he did not have to !?!? Personally when I commission a new boiler , I gas rate it , test working pressures , differential temperatures , analyse it and leave printouts in the benchmark as proof of date of work , I don't want to stir things up but is it not a legal requirement to carry out all tests and leave printouts ??
Hi Phil ,I've been gad safe registered for 15 years since I was 23,I'm not one to stitch other plumbers up but he's clearly fobbing the lady off , he did leave his gas safe number on the benchmark just can't believe he told her he did not have to fill out basically 70% of it .
You shoud see admin and register fully for the private forum
Hold on
....2 accounts ??
Cheers Phil will do , not been on here before not sure how it all works ! Sometimes I feel like I need to discuss stuff I find outside the obvious banter in city plumbing :)
Yeh fot sure. If you bump your posts up to 10 and message a moderator they will tell you what to do and can discuss alot more in the private arena lol
pm gas man once you reach 10 posts
Reply to Benchmark in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
