Discuss Best fitting to use? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Meady
I need to connect onto what I believe is an old 1 inch iron water main. What’s fitting do you guys recommend to join onto it to go to 25mm blue poly?
Cheers
Just pipe at the mo, but I might dig back some more to find a fitting.
Does that fitting just tighten onto the iron pipe like it does the blue poly then?
Yes
Reply to Best fitting to use? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
