Discuss Best fittings for lead in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
I need to replace some lead water main in a house thats being renovated
Its approximatly 20mm OD
What are the best fittings to use?
Lead Loc or a universal fitting like plasson or philmac?
On a house that is being renovated I would want to remove all lead work, - at the very least to outside if entire underground mains not to be immediately replaced.
Philmac I have used on outside pipes
universal fitting not hassle i like philmac but thats me
I am going to cut where it enters the property and recommend they get the external pipework updated.
Whats the likley Internal diameter of 20mm lead?
14-16mm ish
Hi Scott my personal choice would be a lead loc...not 100% sure as I've not used a Philmac transition coupling but I believe you have an element of adjustment when it's tightened up.....someone will correct me if I'm wrong all I would add is to position it where you can get at it in future i.e. Not behind kitchen units.....regards Turnpin:)
Sound advice from Best as per normal.....regards Turnpin:)
Reply to Best fittings for lead in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
